![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
From memory, there was a dyno run listing from a member who discovered his 1NZ-FE was fitted with a 2NZ-FE inlet manifold. It showed a big difference when he replaced the manifold with the correct one. So there may be a difference. I would have to see the 2 side by side and compare.
Of course, if the 1NZ-FE manifold has larger cross section runners, this could actually detract from the midrange on the 2NZ-FE..
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Adding Power Trunk Release Ideas...Need Help | Jrilla | DIY / Maintenance / Service | 12 | 08-23-2009 02:38 PM |
| Plugs for power gains? | lostmind | Performance Modifications | 8 | 07-25-2007 08:19 PM |
| adding power without any cost | OxyG3nE | Performance Modifications | 13 | 04-24-2007 10:24 AM |
