3 Yaris and counting..
It opens the window of customization and repair. I couldn't have done the 4" lift kit without one. Good luck to you sir!
Ain't that the truth! Feels great to be able to do stuff -even simple stuff. Your lift build is awesome. I followed the process. Impressive!
Im actually considering some seriously custom work on that car. Jeep axles, transfer case, chevy ls engine, and a custom frame to hold it all in place. Will give my welder a good workout lol. But I gotta finish my 1987 Cutlass Supreme build first... which also required much welding. Once you have a welder, you want to build everything!
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY: 60/40 Split Seat Install (some welding required) | CTScott | DIY / Maintenance / Service | 13 | 03-05-2017 04:12 PM |
| Inception (movie) | Kioshi | Off-topic / Other Cars / Everything else Discussions | 25 | 08-10-2010 02:08 AM |
| GET FREE PS3/360/Wii check it out! | marcus | Off-topic / Other Cars / Everything else Discussions | 23 | 09-25-2007 06:51 PM |
