Old 03-07-2021, 07:27 PM   #17
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Neinris View Post
I started this thread for everyone, it's not a build thread, so it's really free for all.
Remember the "High Flow Fuel" web site that I PMed you about? They show that the 2008 Corolla has the same motor can as to 09- Yaris.
https://www.highflowfuel.com/product...orolla~zp_1-8l
And here's a pic from RockAuto:
Attachment 61535
If those stats are correct, I might ditch the RAV4 conversion if that's the case.
The 2008 1ZZ Corolla draws less current than the RAV4, has better average flow than the -09 Yaris, and has a higher max PSI than the RAV4!
I think we have a winner!!!
Sounds promising. Here is an application guide for the Beck Arnley pump (152-0989). Correct me if I'm wrong, but didn't the Corolla XRS come with the 2ZZ? If so, this pump must be quite strong.
I noticed that the Delphi pump for the same application seems physically longer than the Beck Arnley pump.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 326 02-15-2025 11:09 PM
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 12:05 PM
Fuel Pump Failure eaglerox DIY / Maintenance / Service 14 03-02-2013 11:27 AM
