Old 03-08-2021, 06:42 PM   #20
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Neinris View Post
Can the top in tank canister be cleaned out, say with water, or does it need to be replaced? Or is it fine to be reused and don't bother messing with it?
Not sure what you're referring to, man. Did you pull your pump?
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 11:05 AM
Fuel Pump Failure eaglerox DIY / Maintenance / Service 14 03-02-2013 10:27 AM
