Old 03-08-2021, 06:50 PM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Sub'd. This is something I've thought would be a great upgrade. Would there be any issues with fluid metering and balancing of brake forces front to rear? The Yaris brakes must be designed to distribute a specific force per axle. The caliper pistons are surely much larger in surface area than the tiny wheel cylinder pistons. I'm no fluid dynamics engineer, but I do wonder about this. Do the rear disk and rear drum cars use the same master cylinder?
EDIT: Not positive, but the 2008 Vitz RS uses master cylinder (47201-52280) and 2008 Yaris uses (47201-52320). May not make any difference.
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
