Old 03-14-2021, 03:43 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Have you put a voltmeter on your alternator? With all those codes, I'm wondering if you're having voltage delivery problems. Of course, you're not having drivability problems, so maybe not.
Old 03-14-2021, 11:01 PM   #2
Neinris
Actually, I didn't... That's why I thought maybe my belt was slipping a bit. It passed the voltage test when I used the ODBII reader. I'll check right now.
Old 03-14-2021, 11:23 PM   #3
Neinris
Ok, so I let her warm up to idle, took the negative cable off the battery, and read the alternator to ground, and she's making +14VDC. So that's not it...
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
P0607 and p0138 cel codes coolguyndc Third Gen Yaris General Discussion 17 08-06-2019 01:52 PM
Found this 2014 Mitsubishi Mirage ES yesterday Hershey Off-topic / Other Cars / Everything else Discussions 97 01-30-2014 11:30 AM
Orlando 2/16 Meet 1.5 Southeast 44 03-28-2013 06:50 AM
Fault Codes P0441, 442, 446 soloecho2 DIY / Maintenance / Service 1 04-25-2010 06:21 PM
