Old 04-25-2010, 07:02 AM   #1
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Fault Codes P0441, 442, 446
My car has started posting these Fault Codes P0441, P0442, P0446 at 1/2 a tank. I'll clear the codes then they will repost sometimes on the next tank or the next at 1/2 a tank. I have couple of questions. (Yes I have checked the gas cap.) 1. does the ECHO only purge the system at 1/2 a tank ?? 2. Does the charcoal canister wear out ?? I am at 276,000 Km. 3. I have access to the 2007 Yaris manual is the 2004 EVAP system the same ?? Any hints or tips will be appreciated.
soloecho2 is offline   Reply With Quote
Old 04-25-2010, 06:21 PM   #2
yarrr
Drives: 07 sedan
look for leaks in the vacuum lines
