Give Me Resonance
Shorter Serpentine Belt?
I may potentially need a shorter belt due to a smaller alternator pulley.
I believe the stock pulley is 3 inches and the one Ill be using would be 1 5/8 inches coupled with the %10 under drive pulley that make for an almost 2" loss. Does anyone know How I would go about making up for this loss?
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
SIPNDEW
if your using the NST underdrive kit with the 3 pulleys then you dont need a new belt. the stock one will work fine.
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
A NAPA store should be able to look-up a compatible belt in any length you need, if its made. Others could too, but NAPA stores seem to have more knowledgeable/willing staff.
Slowy getting there
Go out and buy like the next 3 smaller sized belts belt and test fit. That is what I had to do on a s/c install I did recently and then returned the ones I didn't need.
i had to buy a smaller belt when i put the nst underdrive on....but i don't have a/c
went 36" to 35.5"
Give Me Resonance
thanks guys. dom at irragi alts has the half inch shorter version which should be just fine with the smaller diameter alt pulley (1 5/8)
i forgot how easy it is to move the alt forward and backwards to adjust.
grave digging for the #QCyaris!
| Seat belt buzzer is silenced | billk | General Yaris / Vitz Discussion | 48 | 10-30-2013 09:58 AM |
| Pinging belt when wet or cold | steveh74 | Europe (continental) | 0 | 08-22-2009 05:50 AM |
| Underdrive Pulley Belt | ruimond | Performance Modifications | 11 | 02-14-2009 09:05 AM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-12-2009 11:05 PM |
| Best Grease to use on the belt? | hasher22 | DIY / Maintenance / Service | 11 | 04-23-2007 02:20 AM |
