Crazy, but glad it fixed your issue.
As a side: I have had a vvti solenoid go bad in my H6 Subie which I confirmed with live data. However when bench tested the solenoid worked exactly as it should and resistance across the terminals was within spec. A new solenoid fixed the issue which was also confirmed with live data PID's. Sometimes the solenoids are no longer working properly but bench test fine. In your case it appears it bench tested improperly and eventually fixed itself.
| p0016 bank 1 sensor a (1.3 L 2NZ-FE) | chefslot | DIY / Maintenance / Service | 5 | 09-14-2019 01:12 PM |
