Old 12-04-2018, 06:48 PM   #1
chefslot
Drives: xp90 1.3l 57
p0016 bank 1 sensor a (1.3 L 2NZ-FE)
So whilst exiting a junction, (my car was just about to stall) i had the mil pop on. The code is as above, done 50k and i haven't had time to service it as only just acquired*the car in the last 4 months. After a reset i went for a little drive up the road without any other problems. So i'm thinking it could just have been a glitch in the matrix, a sensor, or the chain may have stretched. Am i right in thinking it will be ok to leave? I don't think it had skipped a tooth as it would still be out now??*
Regards
chefslot is offline   Reply With Quote
Old 12-05-2018, 12:16 AM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Check your oil level, this code is a cam timing discrepancy and it controlled by oil pressure and a solenoid
Old 12-16-2018, 06:09 PM   #3
chefslot
Yes done this, oil was changed in 2017 about 8k ago. Toyota used 5W-30 PFE, even thou they (website) recommend 0W-20, Opie oil recommend the same, The manual and Haynes recommend 5W-30 sl sm, and one site even said about low ash, which i thought was for diesels!!
So i brought this, but might take it back, what do you think
Mobil Super™ 3000 X1 Formula FE 5W-30
but Mobil recommends Mobil Super™ 3000 XE 5W-30, which is low ash,
OR
get Castrol Magnatec Stop-Start 5W-30 A5 Fully Synthetic, which isnt low ash??
Sorry for the late reply
Old 12-18-2018, 02:08 PM   #4
Mike Dexter
Drives: '10 Hatchback
Check for coolant in the oil. These codes can be the first indicator of a bad head gasket. Coolant in the oil impedes is ability to lubricate and can affect chain and cam position.
Mike Dexter is offline   Reply With Quote
Old 12-18-2018, 03:18 PM   #5
chefslot
Thank you, no coolant in oil.
Changed oil and filter and the light has just come on again. Could it be a sensor/sensors and what should the resistance be on the sensors?
Regards
Old 09-14-2019, 02:12 PM   #6
chefslot
So i've changed the CMP sensor and cleaned its triggers, then decided to hook it up to a scope and now it is looking like chain stretch, as you can see from the known good you can count from peak of CMP 9 CKP triggers, and yet mine only have 8. So it appears the chain has stretched causing my timing to retard. Just posting to end the thread.
https://flic.kr/p/2hfjHG6
https://flic.kr/p/2hfhSDW
2006 Yaris (2NZ -FE 1.3) - P0010 bung206 DIY / Maintenance / Service 3 03-19-2018 03:33 AM
2006 Yaris (2NZ -FE 1.3 L) squeaking belt noise bung206 DIY / Maintenance / Service 1 06-21-2017 01:48 AM
NEED ENGINE CHECK LIGHT CODE LIST Attitude Forced Induction Forum 12 04-11-2011 07:38 PM
