Old 07-01-2021, 10:34 PM   #1
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
Just my .02 cents just make sure you greased the caliper slide pins. Maybe the piston is stuck but I'd doubt that. I've never heard of hard to put in pads as being a problem as making them stick if they are stupid hard just grind the part of the pad where it contacts the caliper bracket makes it easier to get on and off if you grind too much it will just rattle a little. If they stick bad you will smell it.
Cletus Garfunkle is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
Passenger side caliper loose... baseballfan416 DIY / Maintenance / Service 5 08-17-2016 11:35 PM
Anyone care to make a DIY on break flushing and bleeding? Hard_Yaris DIY / Maintenance / Service 19 05-04-2011 04:49 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 04:36 PM
