Old 04-21-2022, 09:43 PM   #1
remcafee
if its accelerating under load, its a driveline issue, look at your cv joints and makes theres no grease splooging out everywhere, check your transmission fluid, could also be an internal issue with the tranny, if its an automatic, the torque converter could be having a shudder
Old 04-27-2022, 02:17 PM   #2
esse10
Drives: 2009 yaris 2 door
noise
thanks for your input. the cv joints are solid and there is no grease or oil spills and make no noise when turning. i replaced the manual tranny oil last year and there are no signs or leaks. i know that the clutch shudders once in a while when taking off but it's had that for the last 5-7 yrs this new noise just recently started about a month ago. It kinda sounds like it's coming from the tranny gearbox area. Does the gearbox have a bearing?
Uh oh another engine bay rattle.... YAR1S DIY / Maintenance / Service 15 06-02-2014 05:56 AM
rattle in right side rear cargo area D-Flo DIY / Maintenance / Service 17 05-13-2014 11:17 PM
Rattle noise under the speaker’s cover - sedan karat747 DIY / Maintenance / Service 1 10-22-2011 08:41 AM
Please help with Rattle coming from cam cover? c-dub DIY / Maintenance / Service 11 08-07-2011 09:33 PM
2010 US 5 door stock exhaust, big rattle 127.0.0.1 DIY / Maintenance / Service 3 06-20-2010 09:39 AM
