well youve got a few options
the arm rests on a shaft, then below that is a pin and push rod(these often click on many makes n models) then at the end of the pushrod it goes into the power booster and thru the firewall..again a good click point..youve also got the brake switch itself..which if loose or going bad will click or squeek if its inside the car stick your head under the dash and wiggle it around and finding it isnt hard |
#2 | |
![]() Drives: Yaris Join Date: Dec 2021
Why is it, I only hear the click when the car is moving and I brake lightly ? If I press the brake when the car is still, no noise at all ?
| Brake Failure only when pressing the pedal gently | paraklas | General Yaris / Vitz Discussion | 1 | 01-17-2021 11:26 AM |
| Soggy Brake Pedal | 06YarisRS | DIY / Maintenance / Service | 3 | 07-14-2020 11:56 AM |
| Hiss or pfft when pressing brake pedal | kwk442 | DIY / Maintenance / Service | 3 | 06-03-2017 06:10 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| Brake pedal vibrates-not rotor problem | rradhay | DIY / Maintenance / Service | 9 | 11-12-2010 09:10 AM |
