Old 07-04-2022, 12:23 PM   #2
sh0rtlife
well youve got a few options
the arm rests on a shaft, then below that is a pin and push rod(these often click on many makes n models) then at the end of the pushrod it goes into the power booster and thru the firewall..again a good click point..youve also got the brake switch itself..which if loose or going bad will click or squeek
if its inside the car stick your head under the dash and wiggle it around and finding it isnt hard
Brake Failure only when pressing the pedal gently paraklas General Yaris / Vitz Discussion 1 01-17-2021 11:26 AM
Soggy Brake Pedal 06YarisRS DIY / Maintenance / Service 3 07-14-2020 11:56 AM
Hiss or pfft when pressing brake pedal kwk442 DIY / Maintenance / Service 3 06-03-2017 06:10 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Brake pedal vibrates-not rotor problem rradhay DIY / Maintenance / Service 9 11-12-2010 09:10 AM
