my solution would be a totaly different direction
run a smaller secondary battery with an isolation unit, idealy maybe a drag racing battery like one of the 3 cell optima, mounted in the trunk with HEAVY guage battery relocation wiring this then allows your to jump, charge and maintain BOTH batterys and everything works with nothing more than the flip of a switch for the isolation relay, nothing to carry nothing to use jumpers on(which are a crap connection anyway)...heck you could even use a wheelchair AGM the trick is you just need something with an "ok" amount of CCA |
#2 | |
![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
I think that SJ1329 may be small enough to keep with the spare tire in my hatchback, which is the closest thing I have to a trunk. This is pretty close to what you are suggesting, except for the jumper contacts, which as you say may not conduct that well. On the other hand, in thinking about it, I guess there would be some increased resistance from the long cables in your solution, but I'm not sure it would be significant. The jumper also requires manual charging, which is another inconvenience and difference compared to what you are suggesting. I'm hoping to keep the spare tire area cooler in the summer by attaching a strip of reflectix to the underside of the spare tire compartment cover using velcro. I can then remove the reflectix in the Winter. And I may also add some old plastic bottles filled with water and put them in the spare tire area to moderate the temperature extremes; that is, try to keep the temperatures closer to an "average." I will let everybody know how well the SJ1329 fits in the spare tire compartment of my hatchback. Thanks to everybody for their input. R. Last edited by RMcG; 08-21-2022 at 06:26 PM. |
| Tags |
| jump, lead-acid, lithium, starters |
| Starter Problems - Heads Up | tmontague | DIY / Maintenance / Service | 6 | 03-01-2019 10:04 AM |
| Noobie Advice Needed | ianmak | UK | 7 | 10-17-2017 02:00 PM |
| Advice on wheel spacers and sway bars needed! | Lars | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 12-05-2013 11:28 AM |
| Bazooka A100 subwoofer install advice needed | LugNut | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 07-09-2012 11:02 PM |
| Yaris 06 T Spirit advice needed ! | nocturne_sa | General Yaris / Vitz Discussion | 1 | 01-03-2010 05:24 AM |
