Old 08-21-2022, 02:51 PM   #9
sh0rtlife
my solution would be a totaly different direction
run a smaller secondary battery with an isolation unit, idealy maybe a drag racing battery like one of the 3 cell optima, mounted in the trunk with HEAVY guage battery relocation wiring
this then allows your to jump, charge and maintain BOTH batterys and everything works with nothing more than the flip of a switch for the isolation relay, nothing to carry nothing to use jumpers on(which are a crap connection anyway)...heck you could even use a wheelchair AGM the trick is you just need something with an "ok" amount of CCA
jump, lead-acid, lithium, starters
Starter Problems - Heads Up tmontague DIY / Maintenance / Service 6 03-01-2019 10:04 AM
Noobie Advice Needed ianmak UK 7 10-17-2017 02:00 PM
Advice on wheel spacers and sway bars needed! Lars Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-05-2013 11:28 AM
Bazooka A100 subwoofer install advice needed LugNut In Car Entertainment + Electronics (audio / video / alarm) 9 07-09-2012 11:02 PM
Yaris 06 T Spirit advice needed ! nocturne_sa General Yaris / Vitz Discussion 1 01-03-2010 05:24 AM
