Old 08-22-2022, 09:36 AM   #1
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
Originally Posted by teddy View Post
Unfortunately no. I ultimately went back to the original non-LED bulbs. The LED lights had flicker in the DRL and were way too bright. Once I was back on the old bulbs the indicator worked again.
I did some digging on the interwebs last night and it looks like most with this problem added a resistor in line and it fixed the problem. Apparently the LED's can cause some tricky problems. Anyway, I found a solution that essentially is a plug in. Just in case you ever want to go back to LED's in the future.
There are various ways to do this but this will work as a plug and play solution:
https://www.superbrightleds.com/moto...-load-resistor
TommyWasabi is offline   Reply With Quote
Old 08-22-2022, 10:29 AM   #2
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Huh, that looks simple enough. I wouldn't go back to LEDs - the housing isn't designed for them so at night I was blinding oncoming traffic.
I'm waiting for my Corolla Hybrid to come in, so will be saying good bye to Yaris after almost 15 years :)
teddy is offline   Reply With Quote
Yaris Verso High beam problem henry33 DIY / Maintenance / Service 1 09-21-2016 09:31 PM
rear axle beam compatitbility? AndreS123 Third Gen Yaris General Discussion 3 08-25-2016 04:23 PM
Front wipers high speed not working properly WildChild DIY / Maintenance / Service 1 07-30-2016 01:00 PM
Dimmed high beam as DRL? Ot_tO Cosmetic Modifications (Exterior/Interior) 5 08-21-2012 12:34 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
