Old 09-21-2016, 12:20 PM   #1
henry33
Drives: yaris1.33
Yaris Verso High beam problem
I have very rare problem. when I switch on the high beam (indicator lever pushed to front) the lights do not react to this.
When I pull the lever the high beams are working.
any suggestions ?
henry33 is offline   Reply With Quote
Old 09-21-2016, 09:31 PM   #2
Just to verify - Do you have the headlight switch on before trying to switch the high beams on via the forward position?
If you do, I would suspect the headlight switch being the issue.
High Beam Problem chillmaster89 Cosmetic Modifications (Exterior/Interior) 9 07-18-2013 06:48 AM
Right High Beam Keeps Going Out LEXX DIY / Maintenance / Service 1 07-20-2012 01:42 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
