Old 05-09-2013, 08:14 AM   #1
chillmaster89
High Beam Problem
About 3 months ago my passengerside highbeam stopped working, I thought it was just the bulb, I install Sylvania SilverStar Ultra bulbs part #9003SU-2. And the passenger side high beam still doesnt work. any suggestions? Should i just replace the socket or the whole assembly?
chillmaster89 is offline   Reply With Quote
Old 05-09-2013, 01:29 PM   #2
I would double check the replacement bulb, as the silverstars are very fragile. If the bulb filament is good, then it is likely the socket (which will be visibly melted or corroded).
Old 05-09-2013, 06:14 PM   #3
chillmaster89
The bulb is in working order the socket looks burned out, any ideas on replacement sockets and the easiest way to do that?
Old 05-09-2013, 06:41 PM   #4
Replacement H4 sockets are easy to come by. Most autoparts stores stock them. You will have to cut the existing one off and splice the new one on. Solder and heatshrink is the best way to do so.
Old 05-09-2013, 07:16 PM   #5
chillmaster89
Thank you for your help...now to find an excuse to install foglights...
Old 05-09-2013, 08:21 PM   #6
It is easier to replace the connector with the headlight removed. which requires disconnecting the top of the bumper, and hence is the perfect time to do the fog light install.
Old 05-10-2013, 05:33 PM   #7
toad
toad's Avatar
Drives: street-legal go-kart
i'm thinking i should probably replace my sockets too. i had silverstar ultras for a couple years and they melted them pretty good! went back to regular headlight bulbs as i couldn't afford to keep replacing them every 6 months or so. fortunately, as bad as those sockets look they still work!
toad is offline   Reply With Quote
Old 05-11-2013, 09:31 AM   #8
chillmaster89
Can you recommend a good pair of fog lights that for the 2008 sedan non S model?
Old 05-11-2013, 02:22 PM   #9
The Micro image kit:
http://shop.microimageonline.com/Fog...?categoryId=-1
Old 07-18-2013, 06:48 AM   #10
chillmaster89
UPDATE: I replaced the socket and yet the passengerside high beam still does not work...any suggestions? The fuses are all in working order.
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
HOW CAN I KEEP FOGHLIGHS ON WITH HIGH BEAM? derickveliz2 DIY / Maintenance / Service 27 03-25-2009 04:53 PM
High Beam Issues urbanmindz In Car Entertainment + Electronics (audio / video / alarm) 0 03-19-2009 09:22 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
