Old 09-25-2022, 10:38 PM   #1
remcafee
Originally Posted by Gideon View Post
I wasn't really a fan of the OBX pedals offered and after talking with an MR2 owner about aftermarket pedals they told me that I look into going with the IS Sport pedals since it's a very common modification to do to other Toyotas and fairly simple.
After realizing that no one had in the Yaris community I figured why the heck not!
Simple for others doesn't translate to simple for us unfortunately. Because the USDM Yaris has a nasty plastic blocky shaft as a pedal with no pin holding the pedal in place as it's molded to the plastic, I had to find a replacement pedal. Which is where the IS250 pedal comes into play.
The sensor plug is identical and the pedal can just be plugged in without any modification. However the mounting holes on the pedal assembly are reversed on the IS pedal, which requires you to open the pedal assembly and transplant the inards to the Yaris pedal.
Unfortunately the angle of the pedal shaft is totally wrong and you wouldn't get more than 20% in to the pedal travel before it hits the carpet, so you have to do some bending to the shaft to make it work.
Definitely makes the cabin look sportier. I still need to make some minor adjustments to the pedal, since it's angled back more than I would like, but otherwise feels very nice.
has anyone else done this? so all you did was swap out the electronic throttle components over to lexus pedal and then had tobend the shaft a bit? did yoy verify youre getting 100% throttle?
Old 09-26-2022, 01:46 AM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
I have, except I bought the NCP131 Vitz RS pedal bracket from Amayama so I didn't have to bend my pedal arm. Bolted straight in like factory. Not sure if it works in the 2nd gens though.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 09:55 AM
WTB: Gas Pedal ASsembly... Nexus1155 Items for Sale by private party 0 09-16-2007 09:29 PM
Gas pedal fmicle DIY / Maintenance / Service 12 03-31-2007 12:08 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
