Old 10-15-2022, 06:19 PM   #1
k98shooter
Drives: 2012 Yaris Hatchback 3 door
Thank you, just ordered both inner and outer from Rock Auto. Will be replacing outer one as well, as I have to disconneet it anyway. They also told me the driver side strut is bent and the struts need to be replaced as a pair, can't kust replace one side. The car was hit on left front wheel while making left turn and alignment is totally out of whack... minor fender dent other than that. I ordered pair of KYB struts. Wondering if I should had ordered new coil springs as well. The car has no sag, so I thought I could reuse existing coils.
k98shooter is offline   Reply With Quote
DND Tie Rod Shifter Sale fnkngrv Cosmetic Modifications (Exterior/Interior) 2 07-01-2015 03:53 PM
inner tie rod ends tmontague DIY / Maintenance / Service 0 04-25-2015 07:27 PM
Inner tie rod replacement - rack assembly? jwpaine DIY / Maintenance / Service 1 02-04-2015 07:22 PM
trouble with tie rod nut BobTheYaris DIY / Maintenance / Service 3 04-07-2014 07:08 AM
WTB Battery Tie Down Rod Altitude Willing to Buy by private party 3 01-07-2013 10:45 AM
