![]() Drives: 2015 Toyota Yaris MT Join Date: Aug 2021
Replacing front struts and rear shocks questions
Should both sides of the car be jacked up to replace the front struts & springs? Same question for the rear shocks & springs.
For the front struts I was going to follow this video, which looks like he has only one side jacked up. But I'd like verification from you fine folks. For the rear shocks I was going to follow this video. Rear springs this video. If you have any other tricks or tips, I'd appreciate it. I'm doing front struts & springs, rear shocks & springs, TRD rear sway bar, and new wheels. From my research on the forum it seems pretty straight forward, but anything helps. I found these torque specs: Front struts Bottom mounting bolts: 121 ft lb really? That high? Brake hose mounting bolt: 22 ft lb Top spring compression nut: 25 ft lb - not sure what nut this is? Haven't seen it in any videos Top nut: 41 ft lb Stabilizer bar bolts: 55 ft lb Rear shocks Top nut: 18 ft lb Bottom bolt: 36 ft lb Lug nuts: 76 ft lb |
so heres the real answer, if you have a swaybar, jack up both sides, no swaybar you can do 1 side at a time...most cars made after 1970s have a front swaybar at the very least
can you do it 1 side than the other..yes but youll struggle with it more due to swaybar trying to "flatten" the ride out im not sure that the brake line bolt is 22 ftlbs ..might be INCH lbs..... |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
It's easy even with just one jack stand. I've done it one at a time in the past. Once the corner is on a stand, I would remove the jack and use it to lift up the lower control arm to square off the sway bar link, for ease of removal.
Since you have four jack stands, as long as you're on level ground, why not just put the car on all four? Remember to loosen the lug nuts first before you lift that corner. Then you can have someone help you remove things at the same time. The top spring compression nut is the nut that holds the top spring perch. Make sure your spring is being held by a spring compressor before you remove that nut. You'll see it once you remove the top nut that, which is for the strut mount. For ease of installation, I removed the whole plastic and metal panels where the windshield wiper motor is housed. They're not hard to remove, just be careful to not break any plastic tabs, and not to scratch your paint with the metal panel. |
#4 | |
I usually do one corner at a time, with a jack and stand. Just a preference for me. No issues. I've done shocks a couple of times this way, and wheel bearings a few times. |
| Tags |
| lowering springs, rear sway bar, shocks, struts |
| Tokico Blue Struts and XD Shocks | rexseesyou | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 03-18-2014 07:46 PM |
| Stock OEM front struts, aftermarket rear shocks? | rexseesyou | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-25-2014 01:16 PM |
| Pros and cons of only upgrading to stiffer rear shocks? | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 02-05-2010 12:31 AM |
| Need to get struts for front and rear | alan1828 | Canada | 0 | 09-01-2009 02:09 PM |
| WTB: Stock front and rear struts | heeroyuy01195 | Willing to Buy by private party | 4 | 06-15-2009 01:02 AM |
