Old 02-04-2010, 06:02 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Pros and cons of only upgrading to stiffer rear shocks?
So debating about getting a full set of tokikos. One of my rear shocks is showing signs of leakage and i get some mild rubbing in the rear occasionally. If i bought only rear stiffer shocks but left the front struts oem would this made the car react abnormally.
I have heard of people with adjustables stiffen the rear up on fwd cars to get better handling through corner while running the front softer.. My current suspention setup is on TRD springs. Ofcourse cost is a factor and if i change my mind to get front struts later it would probally be cheaper to just buy all 4 at once. What do you guys think?
Old 02-04-2010, 06:48 PM   #2
I say just buy all four at once. I'm not a suspension guru, but I don't think the car should react abnormally, unless you get some SUPER dampened shocks (which the Tokico blue's shouldn't be too much).
Old 02-04-2010, 07:04 PM   #3
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
I was thinking the same thing YarisSedan, let see what the suspension gods have to say...
Old 02-04-2010, 11:31 PM   #4
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I can't imagine it upsetting the balance of the car too much. Maybe a bit more lift off oversteer until you get the chance to do the fronts, but that's about it.
Considering that the rears are so easy to remove and replace, go for it.
rob323 is offline   Reply With Quote
Different brands of speakers....pros and cons myt In Car Entertainment + Electronics (audio / video / alarm) 2 09-26-2007 02:50 PM
