![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
Wouldn't this solenoid be controlled by the ECU? How would the ECU know that a different solenoid was installed? Wouldn't it just energize this solenoid at 4000 rpm just like the other one? What am I not understanding?
I'm with you.
Also, as far as I know, in the Canadian and US markets, the RS or S models did not get anything different over the lower trim levels.
im wondering this also, but i also wonder if it gives some "feedback" to the ecu, or if the channels in it are cut differently enough to make a big change...thats why i went hunting for any referance to it i could find thru toyota
#4 | |
i have turned this up tho "yaris" stock US(verifyed) part numbers 1533021011 15330-21011 1533021010 1533021020 "echo" numbers 15330-23010 "euro" yaris 15330-40020 now these number were all pulled from ebay...so...i dont know how acurate any of it is...but it raises a big question... why are there 3 different units for the same engine a "revision" from the gen1 to gen 2 makes sense..so lets write that one off...but why is the "euro" and "US" spec parts 2 different numbers for the same year range? i still cant verify finding a RS part number tho |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
Got the numbers for you and its 15330-21020 for the solenoid, so appears some of your USA motors got this one. ( I just researched and USA were sold the RS yaris, which came with this solenoid, thats why you have it listed in usdm)
maf sensor number is "c" 22204-22010 No idea about this brand, but they are cheap! https://www.aliexpress.com/i/1005001388213512.html It has ALL the RS chassis numbers listed but not the the standard chassis like ncp90. The sellers seem to sell any of the numbers as "matching" so becareful if you order to make suire it is the RS designed one. And just looking at it, its going to have a LOT more oil flow to the vvti assembly, I just looked up that stock european one and and it only has two small slots, so way less oil flow. Considering the vvti assembly is a known failure point for the engines I think I like the idea of more oil flow, as for performance is does feel like vvti is coming on sooner. Last edited by Compeer; 11-23-2022 at 08:03 PM. |
#6 | |
But I just looked up other toyota "performance" engine variants and they have the same design for example here is the 2zz-ge's unit. It also has the step down and the extra outlet holes.
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
#8 | |
#10 | |
ALSO got to wonder what the clocking on the side is for!???? OEM RS doesnt have that, its just set where its at. |
| Tags |
| vvti solenoid |
