Old 12-12-2022, 04:52 PM   #1
remcafee
oh yeah and not to mention that iridium is more conductive than copper so it takes less voltage to spike and fire the spark, so you are also prematurely wearing out the ignition coils
Old 12-13-2022, 08:13 AM   #2
bronsin
bronsin's Avatar
An interesting theory. Can you quote a source on that?
Old 12-15-2022, 03:54 PM   #3
remcafee
its pretty simple basic electrical theory, you will change the flow (resistance) of electricity with different conductive materials. the ignition coils store and spike voltage specifically for iridium spark, think of it as a magnet, a magnet sticks worse and better with different metals
Old 12-17-2022, 12:39 PM   #4
Compeer
Drives: NCP90 TRD Yaris Manual
Yeah I actually have coppers in my car but will go back after reading up more about them. The older platinums are straight up worse than copper but last longer. The iridiums provide better performance at lower amperage and last longer and are more resistant to melting.
In saying this all the race engines use copper in the 1nz-fe but they do not care about longevity of stock parts or fuel efficiency.
I read this below and it enlightened me some
https://www.enginelabs.com/engine-te...-from-opinion/
I think I will get NGK BKR6EIX-11 online, the are one step colder but still listed for 1nz-fe. I like to rev it and want to track it one day so this is a good choice for the "spirited driver" who does not live in a very cold location.
Compeer is offline   Reply With Quote
Spark plug gap for Toyota Platz 2005 1.0L expee15 DIY / Maintenance / Service 2 09-22-2021 05:49 AM
Replacing spark plug wire with bell wire bronsin Off-topic / Other Cars / Everything else Discussions 1 11-11-2020 01:17 PM
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 06:10 PM
Spark plug replacement vinny121 DIY / Maintenance / Service 3 08-29-2013 12:25 PM
How hard I should try to remove spark plug mf4361 DIY / Maintenance / Service 24 03-30-2013 02:07 PM
