Old 12-16-2022, 01:48 PM   #1
sh0rtlife
uhh sounds to me like he fully undid the top bolt of the alt and swung it out past "normal operation" in an attempt to get the belt on IE the alt is now touching the AC pump..and while you cna get a belt on that way youll never get the alt over the "tight spot" youve created in the arc of the alt swing..
pull the belt put the alt back TIGHT to the block and stuff the belt on all the correct routing and do the water pump last
Old 12-16-2022, 03:35 PM   #2
I believe right you are.
Tags
serpentine belt
Determining proper tension for new serpentine belt RMcG DIY / Maintenance / Service 11 12-30-2021 06:01 AM
Which serpentine belt? courtartanis DIY / Maintenance / Service 0 11-30-2017 10:32 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 10:41 AM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 12:28 PM
