Old 01-04-2023, 04:42 PM   #1
tmontague
tmontague's Avatar
Originally Posted by JParsons View Post
I am attempting to replace the serpentine belt in my 2007 1.5L Yaris. The old belt slipped off easily enough, but I’ll be danged if I can stretch the new one on. I can get it over the crankshaft, AC, and waterpump pulleys, but the alternater pulley (smallest and most readily accessible of the four pulleys) seems too far for the belt to stretch.
I compared the new belt to the old and they appear to be the same length. I called the parts store and asked them to reconfirm the part number (Continental 4040465) and they say it’s correct.
I finally unbolted the alternater from its top bracket so I can swing it down far enough to get the belt on, but no way can I swing it back up to the top bracket now.
There is no tensioner pulley or any other way to gain slack besides moving the alternater, so what gives? How is this supposed to be done?
You likely have the belt incorrectly routed around the timing mark's "ear" around the 12oclock position on the drive pulley. You will almost never see it unless you know what to look for and it will cause your belt to fall short no matter what you do.
Triple check that area and reset the belt in the correct routing and you will be fine.
Ask me how I know...
serpentine belt
Determining proper tension for new serpentine belt RMcG DIY / Maintenance / Service 11 12-30-2021 06:01 AM
Which serpentine belt? courtartanis DIY / Maintenance / Service 0 11-30-2017 10:32 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 10:41 AM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 12:28 PM
