Old 01-07-2023, 05:01 PM   #1
sh0rtlife
it really depends on a few factors
how hard do you drive?
do you like to carve corners and maintain speed or do you slow down?
what size tire are you running?
all said i think its going to be great improvement, HOWEVER unless your driving hard enough on grippy tires to FEEL the rear of the body lift and start rolling on the corners your just adding weight
i still dont have one.,,but last summer after the brake work and the swap to grippier tires ive found corners where i can FEEL the rear flex and lift....and i see 3 that can be ordered up
toss 100-200lbs in the back seat, go for a drive in the twisties, remove the weight and go do it again and if you cant feel the change in how the rear acts you dont need a sway bar..if you can feel it..you need one
Old 01-08-2023, 03:35 AM   #2
ethanjleighton
Drives: 2007 1.3vvti Yaris
I’m running 15 inch tires(I’m not sure what they exactly have but it’s the stock size). I would say I drive pretty hard most of the time but I’ve been looking for some easy mods that don’t require a lot of time to fit. But I’m kind of inexperienced although I’m training to be an agricultural engineer so I currently have a basic knowledge of how to fit things but I know how things work.
ethanjleighton is offline   Reply With Quote
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
rear anti sway bar = better mileage? Lewis Fuel Economy Forum 42 12-04-2009 10:42 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? thomasward00 General Yaris / Vitz Discussion 3 07-12-2007 01:22 AM
