![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
what are the dtcs? p0355?
honesly ive not noted the code number aside from it specifically stating crank position sensor error
i know its in the system currently tho as i cleared it went for a rive and it came back within mins...."sometimes" i can get away with a reboot and be fine for a few days what gets me tho is everything points to an RPM event failing them...so im almost wondering if theres an "over-volt" at higher rpms..maybe the alt is putting out to much in a specific spot? ZERO other issues, not even in the cars history...save for the more recent airbag issue, which i fixed today..it was the snail behind the steeringwheel wifes owned it since new soo i know the cars history very well 188888Kilometers as of earlier today aside from the spark plugs, brakes, belt, tires, battery(lasted 100k too) and adding AC nothings been changed on the car...and the crank pot blew before i did the AC so can rule that out i hate the thought of cutting into the wiring to "try" and find something, but yeah them crank pots are good eatin NOM NOM NOM |
| How long do TPMS sensors last? | NYC-SE | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-08-2020 10:56 AM |
| shattered crank shaft pulley | maddie | DIY / Maintenance / Service | 3 | 07-04-2016 07:40 PM |
| timing chain or faulty sensors | almcheung | DIY / Maintenance / Service | 3 | 08-16-2011 09:33 AM |
| TPMS Sensors with Toyota Alloys? | Lil Abner | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 06-20-2011 11:29 AM |
| crank, fire, hesitate, crank, fire, run, gas smell | twowheels | General Yaris / Vitz Discussion | 9 | 06-25-2009 07:11 PM |
