Old 02-11-2023, 11:39 AM   #1
Neinris
Drives: 08 Yaris 3 Door Hatchback
Originally Posted by sh0rtlife View Post
ive got a shop local that i get custom braided lines from for CHEEP..so that would be my fix lol
My suggestion to you is to not go steel braided line in the rear, but the front, to soften the braking power in the rear since you’re hell bent on keeping your 14s.
Most likely, I’ll be installing my conversion next weekend. I think I know what I’m going to do with what I have.
Neinris is offline   Reply With Quote
Old 02-11-2023, 01:56 PM   #2
sh0rtlife
when i flushed everything and put the drilled n slotted up front and new drums in the rear i put all braided lines on it because something was feeling "off"..turned out one of the lines was deteriorating on the inside..which is more common than you think....so ive allready got the braids
i think at this point im more curious as to how the hand brake cables and your adapter go together
Old 02-11-2023, 04:45 PM   #3
Neinris
I hope this pic helps. I didn’t put the cable through the hole yet, because it’d be a bit of a challenge to remove. Now what is the concern again? Worried the cables will be too short? The mechanism pulls from the top, but it’s clocked closer to the parking brake cables. So I think they’d be just right.
Get the calipers meant for the Yaris, and the cable length will not be of any concern.
File Type: jpeg 931F09D2-E9AB-4CC6-8F61-EA0D47560F4A.jpeg (331.8 KB, 70 views)
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
