Old 02-13-2023, 07:33 AM   #1
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Originally Posted by Neinris View Post
I've thought of doing the pedal swap in the future. Would you share how you mounted the pedal? Did you make an adaptor plate?
The gen 3 Vitz RS has its own OEM pedal bracket so I just ordered one from RHDJapan. I don't know if it will work in a 2nd gen though.
Part number is 78114-52020.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 02-13-2023, 02:59 PM   #2
Neinris
Drives: 08 Yaris 3 Door Hatchback
Thanks! Does it look like something like this? If so, did it feel weird that the pedal moved forward? The second and third gen's throttle pedals are the same btw.
Neinris is offline   Reply With Quote
Old 02-13-2023, 09:25 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Sort of, its metal though and raises the pedal up about an inch which makes it almost level with the brake and clutch, makes heel-toe a breeze. The Lexus pedal I pulled out of the junkyard had that spacer, I didn't end up using it though and threw it out.
2014 NCP131 5 Speed
Old 02-14-2023, 11:53 AM   #4
Neinris
Thanks! I can probably make such an adapter plate. It won't be pretty, but I won't see it so it'll be ok.
Old 02-14-2023, 06:17 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
If I remember right, the bracket was only ~$12 CAD on RHDJapan's OEM store lol
2014 NCP131 5 Speed
Old 02-14-2023, 07:31 PM   #6
Neinris
I'm not sure if you've looked recently, I punched in that PN 78114-52020, but it's no longer available.
Old 08-30-2025, 08:44 PM   #7
Sokal13
Drives: 2013 3 Door
I tried to PM you but I think because I’m a lurker I can’t actually send PMs.
I’m trying to replicate your set up with the IS250 gas pedal. I got the bracket from Amayama and maybe I’m just being stupid, but I can’t seem to figure out how to mount it.
Did you need to drill and tap a hole or were you able to line the bracket up? I’m assuming the bracket is longways vertical like the parts diagram shows.
The Amayama diagram isn’t very helpful.
I’d appreciate any help you’re able to offer. I’d figure I’ll take photos and write it up for the next person while I’m at it.
This is what the mounting spot looks like on my 2013 USDM Yaris.
Thank you for your time.
Sokal13 is offline   Reply With Quote
1ZZfe mod info darkMINI Performance Modifications 21 07-12-2011 11:41 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
