#1 | ||
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
The volt Injectors I picked up ![]() I have been busy porting and polishing the RS inlet manifold and made it an adaptor plate, now there is a nice rounded lip into the larger diameter instead of a hard edge. the inlet has had a nice internal sanding as well to remove any hard edges. It's very soft alu and with shellac and the gasket paper facing the throttle body and the original oring this should seal perfectly. ![]() Polished the inlet manifolds exhaust ends as they all had a lot of sharp edges inside from the casting just like the main inlet had.
#2 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
I'm not happy with my current 31 MPG/7.58757 l/100km to and from work. It's mostly city driving, but still. ![]() That's why I'm hesitant to put the "1ZZ" TB back on. |
#3 | |
my wife holds the record imo tho...moving down from canada, car packed to the gills, and a 4x8 trailer behind the yaris also packed ABOVE the roofline of the car and she manages 41.5mpg with it....course the wee yaris still only had around 60k miles on it |
| 1ZZfe mod info | darkMINI | Performance Modifications | 21 | 07-12-2011 11:41 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
