Old 02-19-2023, 04:59 PM   #1
Neinris
Drives: 08 Yaris 3 Door Hatchback
Originally Posted by Compeer View Post
You will have to repair the holes you drill tho, idk man this is your brakes, Do it once do it right.
The Alu bracket will brake as well not just the clip, the brake hoses move back and fourth when pressurized under braking, this is going to stress fracture then brake off the mount right where its bent. It would need a triangle welded in to stop this or for it to be a properly cast unit designed to not bend.
You can do the brake upgrade, just use the stock mount position for the trailing arm and stock brake brackets for now, Later on just move the brackets and change trailing arm position, changing the arms position only requires 10mins and a 17mm and extension and a jack.
Fine, fine… I’ve waited almost 2 years for this rear disc conversion, what’s another week of wait to do them properly. I’ll make the steel brackets at work this week and weld them next weekend.
I painted my front calipers black, but I think I’ll paint them red along with the rear to make them look sportier.
Neinris is offline   Reply With Quote
Old 02-20-2023, 09:07 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
Hell yeah, and I know how you feel, I seen the RS crashed and wanted to do teh brake upgrade and then the car got dismantled. Took me 2 years to find another donor car to do my own swap.
Its a minor upgrade for normal driving but if you live in the mountains or you drive aggressivly/take it to the track then this makes the car feels so much nicer. I had to do a hard stop yesterday on the motorway and she stopped on a dime, she will stop even better with the other suspension back in, just gotta bring myself to do another day out installing it all.
Compeer is offline   Reply With Quote
Old 02-20-2023, 12:46 PM   #3
Neinris
Have you ever thought of relocating the brake brackets that are hitting and move the trailing arms to the top mounting holes again?
I found some clippings of the stainless steel rails from work, they're 1/16 of an inch (about 1.6mm) thick, just what I'm looking for to make the brackets out of. I've made one bracket so far, while I'm on lunch break.
Old 02-21-2023, 02:41 PM   #4
Neinris
Ok, I’ve made the brackets from steel. I drilled holes in the bottom where it’s going to mount so that the weld would hold better. Maybe a little over kill…
I’m hoping that I can convince my friend to come to my house and bring his welder, instead of me coming to his house. It’s forecasted that there’d be freezing rain where he lives this Saturday, but not where I live, although it’s still going to be cold, but Sunday weather will be better. I might weld on Saturday and install everything on Sunday.
File Type: jpeg 9DF7842E-E770-45FE-A92B-6F6117D175ED.jpeg (188.7 KB, 70 views)
Old 02-21-2023, 05:47 PM   #5
Compeer
Yeah but its very ilegal to do so, even moving the mount position is ilegal here.
I would need to get the brakes certed again because if the mechanic notices its "modified" it gets marked as modified and I have to get the entire cars brakes certed...NOT EASY.
Why arent you reusing the original brakets after cutting them off old position?
Old 02-21-2023, 06:20 PM   #6
Neinris
That sucks. You can't even just rotate them even just a little towards the inside so they won't hit the frame?
It's wasn't that hard to make the brackets, and it would be easier to just cut off the original ones that I need to relocate with a hacksaw than grind off the welds, and I don't have a grinding wheel.
Besides, I need to make two additional brackets to weld near the rear wheel hub for the hose that goes to the calipers, remember those don't exist on the drum brake version.
My friend said he'd come here on Saturday, so it's game on this weekend!!!
Old 02-22-2023, 09:02 AM   #7
Neinris
This project is making me lose sleep...
Last night, I was thinking too much about how or what I should be doing this weekend. I think I'll remove the axle frame from the car just to be safe, I don't any sparks near the gas tank, and I just filled up late last week. Not just that, also so I can get a good angle on the brackets I'm going to weld.
I'm going to buy an angle grinder, I found one for $50 USD, I'll try to remove the existing bracket that needs to be relocated and see if I can reuse them, also clean off the other spots where the other brackets are going to be welded down.
I'm debating if I should use the Yaris calipers or the Corolla calipers. It will depend on how the parking brake cable will be routed if the Corolla calipers are used. If you think about it, both the parking brake cable and brake line are on the top for the Corolla, which would make it easier to replace the brake pads, you just need to unbolt the bottom bolt and swing it up.
Old 02-23-2023, 04:43 AM   #8
Compeer
The Yaris brakes are pretty easy to do the brake job on, hardest part is twisting in the calipers (use a pair of needle nose pliers to twist them in)
I think Id go with the yaris set incase the caliper diameter is larger on the corolla calipers, No reason to mix and max brakes when you have the correct front and rear matching set which will give it the correct brake proportion.
I always go with "keep it simple stupid" and its a no brainer to install the matching front and rear brakes.
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
