Old 02-25-2023, 09:40 PM   #30
Neinris
Drives: 08 Yaris 3 Door Hatchback
Originally Posted by sh0rtlife View Post
no i bolted it down fit was fine hole alignment and dowel both....id venture to say that the "carrier" for the hub and even maybe the bearings are actualy the same parts, where the hub pressed into the unit is the only "new part",,,and when you consider tooling costs..the more a manufacturer can re-use the same parts and only change 1 item in the chain the more money they save
for my swap..im keeping the yaris 4x100.....as for the xb1 time will tell is it stays 4x100 or goes 5x114.....i know 114 opens up the world to infinite wheel options and going big brakes is easier tha route
Did you get to measure the dimensions of the xB2's rear axle frame? Will it fit in the Yaris? I just want to confirm.
Neinris is offline   Reply With Quote
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
