Old 02-22-2023, 11:32 PM   #20
sh0rtlife
so i hit a yard today for some xb gen2 stuff and they had a yaris...sedan but whatever no good for me
i took off the rear hub then went and took the one off the xb, DIRECT SWAP, in fact i left the drum brake assy bolted up to the xb..so someones going to be SERIOUSLY confused
so for the 5lug disc rear swap you could use entirely gen2 xb rear stuff, from the splash shield out its all a direct fit to the yaris
ill see about posting some pic's...honestly i dont even think you will need to mill the rotors as theres a "slight" offset in the hub itself
for me however im dead set on 2 things disc brakes that fit my wheels..14s on 4x100..and im slowly solving it
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
