so i found out something intresting
the XD uses the same rear beam as a yaris/prius but is 5x114, and...its drum front suspension is all yaris..except the hubs.. i was digging thru toyotas own parts sheets, as i got a notice that theres an XD thats in a local yard....and its a "release" RS..and i wonder if the relese got a rear sway...same part as yaris btw what im unsure of is if the XD drums are bigger than the yaris oe drums..other than being 5 lug but what this tells me with 100% certanty is if you want to go 5lug the XD parts will get you there....shit i need to look at the front rotors and see if the cross referance to a rolla/camry/xb even toyota DOES NOT cross referance the XB beam to anything but XB....but that could simply be the "tabs" and "ears" for disc brakes....as soon as its not a freak show of weather ill get you measurements off our patchwork xb-2 ROTOR ..rolla matrix XD...caliper rolla XD...... |
#2 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Thanks for looking into this, but I already know that Yaris and xD shares the same suspension and that the rear beam from the xD will fit the Yaris, but which Prius are you referring to? Is it the Prius C with rear drum brakes or the regular Prius with rear disc brakes? The xDs have bigger rear drum brakes, ID is 229mm, Yaris is 200mm. I'm using xD front calipers for my bigger SE front rotors, I believe they're the same the Corolla's and maybe even the xB2 because they all the the same 275mm front rotors.The xDs are 5X100 PCD and so are Corollas, I want 5X114.3 PCD like xB2 and Camry. So no, I'm not using the xD set up. One of the members here, myfirstyota, did an engine swap and also swapped temporarily to the xD front knuckle. See the red car in first post (if you can see the pics, I can't for some reason see his posted pics when I'm at work, but I can see other people's posted pics). https://www.yarisworld.com/forums/sh...ad.php?t=61427 |
| Runstop Rear Disc Salvageable? | ilikerice | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 05-26-2016 04:38 PM |
| Rear Drum to Disc Brake Conversion | Mark-UPI | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 40 | 03-12-2015 11:26 PM |
| Questions About rear disc brake system???? | jyfro_13 | DIY / Maintenance / Service | 4 | 12-22-2009 09:25 PM |
