Old 04-18-2023, 04:08 PM   #1
sh0rtlife
took measurements off the xb2 as i had time and right now im going to say that i think its too wide...i couldnt compare to the yaris but i could compare to the xb1 on the lift and its 5 inches wider at the lug pad....ill happly post the numbers later if you want
hell the springpockets are 6inches deep too!!!!..64ish wide
Old 04-18-2023, 07:18 PM   #2
Neinris
Drives: 08 Yaris 3 Door Hatchback
Yes please, post the measurements. I'd appreciate it very much.
Is the xB1's rear axle frame the same as the Yaris'?
Google says that xB2 rear track width is 59.8" and Yaris 57.5 - 57.9". xBs stock wheels and tires are 205/55R16 on 6.5 inch wide wheels, compare to Yaris 185/60R15 on 5.5 inch wide wheels.
Neinris is offline   Reply With Quote
Old 04-18-2023, 10:18 PM   #3
sh0rtlife
ok so all of this is off of an 08 xb
these numbers are tricky as hell to get with the axle in place..so they are kinda rough and somewhat eyeballed
center of hub to top of caliper 6.5 +.5 hump at bleed screw
3 inch body mount bushing
centerline of body mount bolt to centerline of the hub 15
lugpad to lug pad 63.5(they seem to be fixing the track with wheel offset?)
spring pocket base to top of axle 5.5 inches deep
body mount bolt head to hub face centerline 8
outter edge of body mount to mount seems to be about 47..its hard to get exact with the fuel tank in
honestly im waiting to find a yaris and an xb in the same yard ...then i can pull em both set em next to eachother and see, hell i can even see if it bolts in.....we know the hubs do
Old 04-19-2023, 08:02 PM   #4
Neinris
Yeah, I think it's better to just compare them side by side.
Old 04-20-2023, 12:14 AM   #5
sh0rtlife
pretty sure they are..but...is a sedan and hatch the same beam?
what about the XA beam?
what about echo?
im asking specificaly as my most local yard has an 09 xb and an xa
and i know of another yard that "might" have 08 xb and a sedan..tho said sedan might be an echo?....
basicly trying to find alternative units that are the same unit to use as comparisons...since yaris, and xb dont seem to show up at the same time or be around long enough to overlap
Old 04-21-2023, 09:17 PM   #6
Neinris
what about echo?
I'm not 100% about the xAs, I'll do some research. Do you see any xD? Those a the same as the Yaris.
Old 04-22-2023, 03:00 AM   #7
sh0rtlife
i wish....theres one "forsale" in teh yard that they want WAY too much for that WILL end up in the yard...question is will the xb2 still be there when it does.....i want the mounts n stuff for the 1.8 swap
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
