#1 | |
these numbers are tricky as hell to get with the axle in place..so they are kinda rough and somewhat eyeballed center of hub to top of caliper 6.5 +.5 hump at bleed screw 3 inch body mount bushing centerline of body mount bolt to centerline of the hub 15 lugpad to lug pad 63.5(they seem to be fixing the track with wheel offset?) spring pocket base to top of axle 5.5 inches deep body mount bolt head to hub face centerline 8 outter edge of body mount to mount seems to be about 47..its hard to get exact with the fuel tank in honestly im waiting to find a yaris and an xb in the same yard ...then i can pull em both set em next to eachother and see, hell i can even see if it bolts in.....we know the hubs do |
#2 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
pretty sure they are..but...is a sedan and hatch the same beam?
what about the XA beam? what about echo? im asking specificaly as my most local yard has an 09 xb and an xa and i know of another yard that "might" have 08 xb and a sedan..tho said sedan might be an echo?.... basicly trying to find alternative units that are the same unit to use as comparisons...since yaris, and xb dont seem to show up at the same time or be around long enough to overlap |
#4 | |
i wish....theres one "forsale" in teh yard that they want WAY too much for that WILL end up in the yard...question is will the xb2 still be there when it does.....i want the mounts n stuff for the 1.8 swap
| Runstop Rear Disc Salvageable? | ilikerice | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 05-26-2016 04:38 PM |
| Rear Drum to Disc Brake Conversion | Mark-UPI | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 40 | 03-12-2015 11:26 PM |
| Questions About rear disc brake system???? | jyfro_13 | DIY / Maintenance / Service | 4 | 12-22-2009 09:25 PM |
