Old 04-28-2023, 01:58 PM   #1
sh0rtlife
ive got a matching header to go with the pipes so its all gains
bronsin i totaly get that i really do, but at that same time, if you could make it a lil more fun..why not right?...personaly its very hard to leave anything "stock" ever since i got my license in 91..mod it mod it mod it!...my 58 ford is about as stock as anything in my assortment gets, of course...its also got all the factory goodies, but i did swap out the front spindles for disc brakes which also got me a 2inch drop
the reason tho to go dual while being asthetic is that 1 side will run the "shhh" mode thru the silenced can, the other side will run un muffled straight thru
the new routing will be modified after the axle, turning to the drivers side passing a valve and going into the shhhhh muffler then turn and out thru the other can and tip, while the valve goes out thru a flow thru and tip in the stock local
Exhaust Manifold to Pipe Donut Gasket yarisinpa DIY / Maintenance / Service 1 06-29-2017 03:35 AM
Hole in my Exhaust? Losing Coolant? Peloton DIY / Maintenance / Service 7 02-02-2015 07:51 PM
Exhaust sound "scientific" testing ezhacker1 Performance Modifications 2 01-26-2014 12:04 AM
FS: Thunder Axle-back Exhaust for Yaris LB FunctionSpec Items for Sale by private party 38 06-03-2010 02:33 AM
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
