Old 05-18-2023, 02:11 AM   #1
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
I never spoke to a rep but I think it is stated on the box. It is cool that you were able to speak to a rep.
The filters I Noted are also close to an inch, inch and a half deeper than stock filters.
I have always run Larger filters (via cross referencing inlet since and OD Gasket size since my first 350 chevy. I would run the two quart filters and a deep sump oil pan on a short bed half ton Van. The van had some head work, headers, intake, carb and full MSD ignition. It ran like a scalded gorilla!
Originally Posted by sh0rtlife View Post
FWIW
the wix "xp" filters have more filter material in them with the design specificly to flow more oil thru, they are ment to only be ran with synth....spoke with a rep in great detail about them..its something like 1 extra pleat for every 2 in the filter...the idea is to add 1/3rd more surface area for filtering and allow more oil to flow thru them faster
Calrenman is offline   Reply With Quote
Old 05-18-2023, 11:55 AM   #2
sh0rtlife
i did the same on my mopars, forgive my only remembering the fram numbers, but the ph43 and the ph8a are IDENTICAL bases, the 8 being almost 3x the size of the 43...mind you on my a-body barracudas the 8 only fit if i axed the 90deg OE adaptor, but on my trucks and van the 8 was no big deal..for referance the 8 is your standard for filter while the 43 isnt much bigger than our yaris filters
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
2009 oil filter lcpete DIY / Maintenance / Service 10 04-05-2012 08:05 PM
Oil & Air filter change please help! JAMMAN1701 DIY / Maintenance / Service 2 04-01-2012 09:28 PM
Higher capacity oil filter???? 2006fronty DIY / Maintenance / Service 29 01-06-2009 02:00 PM
