#1 |
![]() Drives: 1.33 yaris Join Date: Apr 2012
2009 oil filter
Hi
First post here ![]() We are a 2 yaris family my wifes is a 2009 and mine a 2011 both 1.33 Anyway decided to start servicing the wifes car as its out of warranty and I've always serviced our cars and motorbikes I went to main dealers and bought oil and filter and noticed that the oil filter is a separate paper one complete with o rings I have seen ones like this on motorbikes but not cars assume its just a matter of taking the cover off and replacing the paper filter and o rings Not actually looked under car yet but I'm sure its straightforward enough but is the any special precautions I should be aware of?
Nic
Drives: 2008 3-Door Liftback Manual Join Date: Jan 2012
I had no idea the Yaris would have a filter like that, but I see you are in the UK. In case you haven't, I would check your engine to see if it has an external oil filter. Perhaps they gave you the wrong one?
If it is the correct filter, I wouldn't think it would be too difficult. I've used that type on my motorcycle years ago and helped my friend change the ones on his bike when we were kids. I never did like them on the motorcycles as it was easy to strip the bolts. I am sure the design is much better on the Yaris. Good luck. |
#3 |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
UK cars might have a different set up, but in the US all Yaris have a spin on oil filter, not a cartridge like the one you've been given. Don't pull the drain plug till you confirm what you have.
#4 |
Thanks will have a look and check
![]() My wife went to the garage and bought the oil and filter I was surprised when I saw the filter not seen one like that on a car before I did a Google search and could not find any info at all But will definitely check before I drain the oil
#5 |
Just found out ,did a search on a UK toyota parts supplier it is the right filter
After 2009 for UK 1.33 engines they changed to the paper cartridge type very odd , modern motorbikes don't even use those anymore Will have a look underneath the car and make sure I can get the cover off before I drain the oil
#6 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
#7 | |
#8 |
Hi Geoff part no of Toyota filter is 04152-40060
#9 |
#10 | |
![]() ![]() Drives: 2011 Yaris sedan Join Date: Mar 2012
I think its mostly just ease of use. if your going to pull a nasty dirty oily filter element out of the car after cleaning it and putting new o rings and whatever its just as cheep to have the cartridge type or the spin on type. Plus i like the idea of a nice new clean filter not a "washed one" also glass fiber filtering media for me please Thanks Sean Scott |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 02:00 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
