Old 05-24-2023, 03:01 PM   #28
sh0rtlife
Originally Posted by Calrenman View Post
Before the valve burned my compression was high normal before the oil test to check the rings with little Slight raise after the ring test.
The motor in the Geo had 100 k on it. My V8s ised to smooth at certain place in the cylinder I think it was top and bottom center and outsid but I ran the piss out of those moters (350 chevy).
Toyota is not what they were in the 90 or early 2000s. Sorry you were burned.
funny enough, theres a post on the carnage in here, but after cleaning it out, swapping the vvt, chain and guides, its quieter than its EVER been and runs perfect...but im still getting shavings in the oil so i question its life span...sad its only got about 120k on it
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
2009 oil filter lcpete DIY / Maintenance / Service 10 04-05-2012 08:05 PM
Oil & Air filter change please help! JAMMAN1701 DIY / Maintenance / Service 2 04-01-2012 09:28 PM
Higher capacity oil filter???? 2006fronty DIY / Maintenance / Service 29 01-06-2009 02:00 PM
