#1 | |
![]() ![]() Drives: 2015 Toyota Yaris LE Hatchie Join Date: Oct 2021
That sucks!
I have no "shinies" when I inspect oil after a change. I hope it works out for you. Try changing the filter again, Maybe it is a brake in or defective filter. ![]() Quote:
#2 | |
"if" the engine goes another 100k ill be blown away, but theres no way it will go the 400k some guys get out of it...even if its only got 120k on it..the carnage from toyotas F-up will inevitably lead to a shorter life on the engine |
#3 | |
I would be worried about the rings but if it is quiet and has good compression think if the silver flakes as aluminum lubricant! Its softer than the rings or the crank!
Burn that puppy to the ground!There is a 1.8 that fits in our cars... neat! ![]() Quote:
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 05:22 AM |
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 05:25 PM |
| 2009 oil filter | lcpete | DIY / Maintenance / Service | 10 | 04-05-2012 09:05 PM |
| Oil & Air filter change please help! | JAMMAN1701 | DIY / Maintenance / Service | 2 | 04-01-2012 10:28 PM |
| Higher capacity oil filter???? | 2006fronty | DIY / Maintenance / Service | 29 | 01-06-2009 03:00 PM |
