Old 06-04-2023, 05:10 AM   #1
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
XD, Scion? If I tried that here in the peoples republic I would be in solitary for some reason or other.
Originally Posted by sh0rtlife View Post
my primary concern is genuinly the bearing surfaces both getting washed with keroseen, disel, engine flush in an attempt to clear as much "flake" out of the engine as i could, i litteraly ran about 8 gallons thru it in the course of a day trying to get it clean....it stopped showing signs so i buttoned it up
1500mile oilchange resulted in seeing more.....so i know 2 things..flakes pushed past the filter for a long long long time(read years) so how much material has been embedded in the bearing surfaces.......which means when it goes it will likely toss a rod or a bearing or both..
so yeah ive started my 1.8 swap gathering..ive got the xd harness, motormounts and some other bits...just keeping an eye out for a low mile cheep 1.8
Calrenman is offline   Reply With Quote
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 05:25 PM
2009 oil filter lcpete DIY / Maintenance / Service 10 04-05-2012 09:05 PM
Oil & Air filter change please help! JAMMAN1701 DIY / Maintenance / Service 2 04-01-2012 10:28 PM
Higher capacity oil filter???? 2006fronty DIY / Maintenance / Service 29 01-06-2009 03:00 PM
