Old 07-10-2023, 03:20 PM   #1
rpster
Drives: '07 Yaris Liftback
I've been eyeing all these 2zr swap threads and think my time has come: My 07 HB's auto transmission finally gave up the ghost (250k og miles, stuck in neutral/drive) and I am heavily considering this swap with my eye on a donor 09 XD that has a manual. So it'll be a double swap for me: 1NZ>2ZR & Auto>Man.
I had a couple questions that weren't quite clear from reading the thread:
1. ABS / Speed signal - Will I need to move over ABS from the XD to get the right speed signals to the ECM? The Yaris has no ABS.
2. Axles - If I'm swapping to the XD trans, I assume I can reuse the Yaris axles?
Thanks!
rpster is offline   Reply With Quote
Old 07-11-2023, 08:15 AM   #2
tmontague
tmontague's Avatar
Thanks!
To answer questions #2: technically yes, but I had binding issues on the front left axle, it turned out to be too long with the new engine. I solved this by using a '98 tercel axle which was an inch shorter but the splines all matches up.
Old 07-11-2023, 01:47 PM   #3
rpster
Looks like this is a relatively easy part to get, thanks for the insight!
I also did more research on the speedo sensor: The C50 on the XD can have a speed sensor added, meaning I wouldn't need to move over the ABS just to have a speed signal!
The only other question is if the driven gear for the speed sensor is already installed or not. I'm planning to open up the donor transmission anyways for inspections so here's to hoping it's already in place.
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
