Old 08-11-2023, 12:41 PM   #1
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
Originally Posted by jayis View Post
I want to update this in case anyone ever runs into a similar problem. I am still waiting to head to a junk yard to get another screw but it's not high on my list of priorities because I have my one screw and nut holding the striker on. I did it by placing the nut in the "closed" box side of a wrench and sticking it in the holes in the rear metal until its below where the striker goes. It takes a few tries but eventually you can get it. Hopefully the pics help explain what I mean. I'm sure you don't have to use the screws and nuts that came with the car, I just wanted to. I found the part number pretty easily for the screw, and they were cheap even from Toyota (<$2). I just want other things from the junkyard anyways so I am not ordering new. Also that little part of the nut that juts out I think helps it grab and stay in place so I wanted to use the real ones.
I am pretty sure this issue is never supposed to happen and those nuts are supposed to be welded on, mine just broke somehow. I even went to the dealership to ask them if there is a part number for the nut and he told me they are part of the frame and he has no idea how they came loose.
Yep, this is how I fixed mine: a link to my post below in case someone finds this and needs more pictures as well.
https://www.yarisworld.com/forums/sh...165#post843165
TommyWasabi is offline   Reply With Quote
Rear brake disks sliding bolt torque Keymaster DIY / Maintenance / Service 6 04-12-2016 03:53 AM
How to set up rear window wash sprayer? Be_Jammin DIY / Maintenance / Service 0 03-13-2016 05:40 PM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
