Old 08-20-2023, 09:05 AM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
Yes and unless its different the clutch feeds from the brake master cylinder and when you bleed the brakes you are supposed to do them in sequence and always finish with bleeding the clutch slave cylinder.
Mine goes all soft and bad feeling if its not bleed correctly after messing with the brakes. Bleed longest line to shortest, on our cars its going to be left rear, right rear, left front, right front, clutch slave cylinder to get all the air out correctly.
When I changed to the RS subchassis I tried to bleed as normal and it was not right until I did the full sequence in order.
Compeer is offline   Reply With Quote
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 12:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 11:42 AM
'07 Yaris Clutch replacement dinop DIY / Maintenance / Service 12 04-22-2013 05:47 AM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
