Old 03-29-2013, 08:36 AM   #1
dinop
dino
dinop's Avatar
Drives: '07 Toyota Yaris (sedan)
'07 Yaris Clutch replacement
Hi there,
I'm new to the forum and was wondering if any of you could help answer some questions I had. I have a 2007 Toyota Yaris sedan that my parents bought as a daily driver back in September '06. As of last summer it has just become a backup car for extended trips or for the days when my Range Rover 'fails to proceed' (as the manual puts it). The Yaris (as of today) has 272k miles on the odometer and is still running well!
I am having some clutch issues though. Every month it seems like its getting weaker and weaker to the point where I feel like if I tried to drain the transmission fluid the whole clutch would just pour out with it! So obviously something needs to be done. My question for you is:
How much would a new clutch cost if I swapped it out myself? Are there any other options rather than the stock Toyota clutch, for mileage or acceleration purposes? Is there anything I can do about the clutch disengaging when the pedal is at the floor? Is there any way to get it to disengage halfway like in my Audi?
The high-mileage club is like the mile-high club...in no way
Dino, VT
07 Toyota Yaris Sedan- stock, 281k, daily driver
09 Toyota Yaris Sedan- stock, 128k...parents car
95 Audi S6- alt daily driver, 5 cyl turbo, 224k
75 Triumph TR6- Current restoration project, 8k
dinop is offline   Reply With Quote
Old 03-30-2013, 06:56 PM   #2
YarTrek
Aygo Crazy
YarTrek's Avatar
Drives: '08 Blazing Blue LB MT
Could be the clutch master cylinder preventing the clutch from disengaging until the pedal is at the floor. I've replaced a few of those on old Toyotas.
YarTrek is offline   Reply With Quote
Old 03-31-2013, 08:59 AM   #3
bronsin
bronsin's Avatar
Yes before you REPLACE THE CLUTCH (or ask the friendly mechanic)
1) bleed the clutch and replace the fluid
2) change the slave cylinder
3) change the master cylinder
A bad clutch:
chatters and shakes and rumbles when you let it out
when in gear with the clutch pedal all the way up accelerate briskly. if the engine revs and the speed doesnt increase you need a new clutch.
try all the gears...
Old 03-31-2013, 09:04 AM   #4
bronsin
bronsin's Avatar
To answer your question:
Look up the parts online!
The clutch in that car lasted more than 200 k miles. Why would you want a different one?
Yes bleed the clutch and if necessary change the slave and master clyinder.
I think it likely the problem is in the slave or master cylinder. In any case bleed the system first. If either the s or m is leeking you found the problem...
Tell us what happens!
Old 03-31-2013, 08:20 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
you'd want a new one because it is more fun! I hated the Yaris stock clutch with a passion. So glad I bought Jason's clutch and flywheel from him. The car feels better, and I can actually feel when the clutch engages.
Colin Chapman disciple
Old 03-31-2013, 08:28 PM   #6
bronsin
bronsin's Avatar
Hmmm did you hate the door handles with a passion? How about the turn signals?
Why would you hate a clutch?
Old 03-31-2013, 09:39 PM   #7
nookandcrannycar
Also do Yarisworld member djct watt 's Standard Clutch Test (post #12 on 06silveryaris 's '45k clutch is going thread'. Just park in a flat location a few car lengths away from another car. Only takes a couple of minutes. I've done this test twice since August 2012.
Old 04-01-2013, 02:08 PM   #8
dinop
dino
dinop's Avatar
Thank you all for the quick response!
bronsin, you've got a point there. Maybe I will go for another factory clutch. I am going to have the master and slave cylinders checked out though. Neither have been touched since we bought the car in 2006.
Dino, VT
Old 04-02-2013, 06:33 AM   #9
bronsin
bronsin's Avatar
If you find one leaking theres your problem.
A bleed may help also....
Old 04-02-2013, 01:25 PM   #10
esse10
Drives: 2009 yaris 2 door
master slave cylinder
Well that's good to hear the clutch system in these yaris last a long time.
might as well replace the master and slave cylinders anyhow cause at 272k miles ,it's time Nothing lasts forever. Usually when the actual clutch is going bad it'll start slipping in the upper gears , like 4th,5th gear as you accellerate.
Old 04-16-2013, 08:25 AM   #11
dinop
dino
dinop's Avatar
I've been looking for that. I've been watching the tachometer in 5th gear @ 50mph but it still revs at 2500rpm like it always has. That being said, I was at a party last night and I had to park on a small slope. Rather than using the handbrake, I just throw the gear lever into 2nd (a habit that carried over from my Land Rover). Anyway, after doing this I let the clutch out and took my foot off of the brake and the car started slipping forward. I've never had an issue with parking the car this way, and when I tried 1st it still slipped a little.
Dino, VT
Old 04-16-2013, 04:19 PM   #12
bronsin
bronsin's Avatar
Sounds like trouble. Accelerate briskly in 2nd and 3rd to a steady speed at relatively high rpms. If it rvs higher the clutch is slipping.
Its all relative though. IF you are carefull with it even a dodgy clutch can last a very long time.
Old 04-22-2013, 04:47 AM   #13
nookandcrannycar
I agree. I've found this to be true with previous cars. The clutch in my Yaris is still fine/not dodgy.
clutch replacement vwtech General Yaris / Vitz Discussion 44 06-23-2017 01:06 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
2000 1.3 YARIS Wing panel replacement jjosull DIY / Maintenance / Service 1 02-12-2013 01:53 PM
