Old 02-27-2024, 10:49 AM   #1
Billiam
Drives: '10 White Yaris 4D LB
Not worth the hassle. It's a $10 part from your local dealer. Replace it.
If you want to enjoy your car, stay off of the internet.
Old 02-27-2024, 11:44 AM   #2
snowblower
Drives: 2014 Yaris LE, France built
That's what I've always done for my Hondas. This is my first Toyota. I may just do that. We'll see. I'm trying not to break the parts bank with this car.
Do you happen to know if there is a spring in Toyota's PCV valve for the 1NZ-FE, or just a simply check valve? I'm more inclined to replace PCV valves that have a spring due to the spring relaxing with age.
snowblower is offline   Reply With Quote
Old 03-01-2024, 10:44 PM   #3
Billiam
It's been 2 or 3 years since I replaced it and frankly don't remember. But I'm fairly certain it's just a check valve. There just wasn't a significant price difference between aftermarket and OEM....especially when you're taking about a $10 part.
Old 03-07-2024, 02:49 PM   #4
esse10
Drives: 2009 yaris 2 door
clean
once a year just remove, clean with denatured alcohol or contact cleaner and put back.
PCV VALVE THREADS DANIELTNIEVES DIY / Maintenance / Service 3 08-17-2015 03:11 PM
Preventative Maintenance tmontague DIY / Maintenance / Service 20 11-05-2014 12:22 PM
PCV valve over tight peewee1 DIY / Maintenance / Service 8 09-01-2013 09:28 PM
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-16-2013 11:06 PM
