Old 04-06-2013, 03:50 AM   #1
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
PCV valve over tight
My pcv valve is sooooo tight i'm afraid I'm going to "tear" or damage it when trying to remove it. All I've tried is the 3/8 ratchet and socket. I thought the engine was going to be pulled out when I tried to loosen the valve. Could I use maybe some penetrating oil, or "heat" from a torch? This s.o.b. is !!!! Thanks for any ideas.......
peewee1 is offline   Reply With Quote
Old 04-06-2013, 09:06 AM   #2
Yaris_80
Proud Toyota Owner
Drives: 2008 Yaris HB
I just changed mine as well, At first I used a 3/8 ratchet and it felt like it was welded on. Step it up to a 1/2 ratchet with a deep wall socket and it'll be easier.
Yaris_80 is offline   Reply With Quote
Old 04-06-2013, 10:21 AM   #3
peewee1
PEEWEE1
peewee1's Avatar
pcv
I took your advise with 1/2 inch ratchet,Plus a nice steel pipe as a breaker bar, I heard a nice snap and it loosened up. Cleaned it out with gunk and reinstalled it. Thanks for the help.
Old 04-07-2013, 11:11 PM   #4
Hershey
Checked it for the sedan . Had oil in it . Still hear the rattle from within , so placed it back in . Should it be cleaned or recheck later ?
Old 04-09-2013, 05:08 AM   #5
peewee1
PEEWEE1
peewee1's Avatar
pcv
While you have it out why not clean it with a little Gunk.
Old 04-09-2013, 11:02 AM   #6
Hershey
Don't have any .
Old 04-09-2013, 11:34 AM   #7
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Dont remove it. Next time you change your oil, spray a bunch of wd-40 in the pcv(before the oil change), and that should clean it just fine.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 08-31-2013, 08:16 PM   #8
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Mine came off easier than i thought. I checked it and didn't see any build up at all.Did the shake test and it was rattling fine inside.But decided to give it clean up with carb cleaner. I also did the throttle body.
Maybe your turning it the wrong way?
Old 09-01-2013, 09:28 PM   #9
esse10
Drives: 2009 yaris 2 door
anti sieze lube
Since you have it off now put some anti-sieze on the threads for next time. Not too much just a little dib on the threads and I guarantee it'll come out real easy a year from now.
PCV Valve SonicGuppy DIY / Maintenance / Service 4 11-12-2014 09:03 AM
PCV valve question window_lee DIY / Maintenance / Service 31 10-22-2014 04:05 PM
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-16-2013 11:06 PM
Two different PCV valve Part#s for Yaris? auxmike DIY / Maintenance / Service 6 03-18-2011 08:55 AM
